pixro
Nov 15, 2025Tutor
No Parental Controls
Hope no one minds the reboot a few years later.... Working with an Orbi RBR750 running V7.2.7.15_5.1.16, and any time I go to add a device to Apple Home, get messages that router does not support ...
CrimpOn
Nov 15, 2025Guru - Experienced User
Netgear routers do not function as a HomeKit server.
The Internet of Things (IoT) WiFi network was created by Netgear to address the problem some users experience when the smartphone app for this new gizmo is poorly written and will not function when the smartphone is connected to WiFi at 5G. Because the IoT network 5G signal can be temporarily disabled (which forces a smartphone to connect to it at 2.4G), the gizmo can be connected and then the 5G IoT signal can be enabled again. The IoT network has nothing to do with HomeKit (or any other "smart home" functionality).
- pixroNov 15, 2025Tutor
Familiar with HomeKit Hubs (in my case a HomePod and iPad, and iPhone all represent Hubs.
Also had a HomeBridge server set up a few years back - this is not part of the ecosystem any longer.
Homekit also requires a homekit compatible router. Given the Orbi is a tri-band (required for Home Kit support) I simply expected HomeKit would be supported by Netgear/Orbi in 2025. Take for example Linksys MX4200 or WHO03 Velops—Tri-bands.
- StephenBNov 16, 2025Guru - Experienced User
No it doesn't.
If you happen to have a homekit compatible router then you can manage the router itself with homekit
But it is not required to connect your other devices to homekit - it is an optional component. AFAIK there are only a couple of homekit routers out there (some linksys models). So I don't think this got a lot of traction in the marketplace.
What devices are you trying to add?
