pixro
Nov 15, 2025Tutor
No Parental Controls
Hope no one minds the reboot a few years later.... Working with an Orbi RBR750 running V7.2.7.15_5.1.16, and any time I go to add a device to Apple Home, get messages that router does not support ...
CrimpOn
Nov 15, 2025Guru - Experienced User
So, the HomePod does not connect to the WiFi network?
- pixroNov 16, 2025Tutor
Two HomePods and an iPad (dedicated to just the iot netowrk) are on the Orbi WiFi 2.5 network.
Adding any device gives the same error.
• Open Home Add• Select add button
• Select new device
• Scan sticker
• Enter code
• Error
Tried 4 devices. Each device manually removed from previous network. Each device factory restored.
- StephenBNov 18, 2025Guru - Experienced User
You mean the IoT network? The guest network isolates devices, so that won't work.
