adrkarma
Sep 23, 2025Aspirant
Orbi 970 SPC Issues
I recently purchased the 970 3 pack. The connectivity is amazing no issues with dead zones or dropping connection. The parental controls are extremely delayed or sometimes not taking effect unless I ...
Sep 23, 2025Guru - Experienced User
Be sure to disable any MAC Address randomizers on phones and pads while at home:
NETGEAR Mobile Applications and Android/Apple/Windows Devices FAQ | NETGEAR Communities
adrkarma
I have mac address randomize turned off on all my devices. The issue still persist. If you use parental controls is there a massive delay when you pause a device?
