Aug 14, 2021Guru - Experienced User
Orbi RBR850 firmware 4.6.3.9 - No SPC tile on Orbi app to set up
Loaded v4 yesterday on the RBR850 that was in AP mode.
Changed to Router mode today and not seeing any Parental Controls tile on the Orbi app as per instructions here:
https://kb.netgear.com/000062109/How-do-I-set-up-and-install-NETGEAR-Smart-Parental-Controls
Armor is listed, just no Parental Controls. Both on Android Pad and iphone 12 Max. Checked for app updates and saw nothing for Orbi app.
I have not done a reset and setup from scratch yet. After FW was sent to system, system was powered OFF for 30 seconds then back ON.
I believe 7 series users are seeing similar experiences as well.
add me to that list
- I have the RBR750 and I’m using version: 2.11.0.11 of the app.
- svetaketuLuminary
Hi FURRYe38 ajneuman LadySapphy,
Based from SPC releases on other models, the FW is first made available and only after a week or two is SPC released.
Christian_R Blanca_O, can confirm if this is the same for this case.
Hope this helps.
- Christian_RNETGEAR Employee Retired
Hello Community,
Just to clarify, we’ve disabled Smart Parental Controls for the initial firmware rollout. However, we plan to enable SPC next week when we start the next phase of rollout.
Christian
Thank you for letting us know.
