chaituphani
Jul 30, 2025Aspirant
Parental control for Orbi router RBR350
Hi, I cannot see parental control tile on my orbi app (version 2.45.1.4740 The router firmware version is V4.20.0.4 Can someone please help me. Also the block sites security does not work. ...
Jul 30, 2025Guru - Experienced User
Check on the app on the top left corner line menu then down to My Subscriptions. Is SPC listed there?
Check Settings/Security and see if it's enabled there?
There is a newer Orbi app update as well: New Orbi App Versions and Updates | NETGEAR Communities
That FW version doesn't seem correct. Can you confirm this version?
What is posted here: https://www.netgear.com/support/product/rbk352/#download
