chaituphani
Jul 30, 2025Aspirant
Parental control for Orbi router RBR350
Hi, I cannot see parental control tile on my orbi app (version 2.45.1.4740 The router firmware version is V4.20.0.4 Can someone please help me. Also the block sites security does not work. ...
chaituphani
The download you mentioned above is for RBK352 whereas I have RBR350
Jul 30, 2025Guru - Experienced User
FYI, the RBR350 is included the the RBK or Kit that has the RBR350 and a RBS350. Same FW versions for for the RBR or the RBK Kit versions.
https://www.netgear.com/support/product/rbr350/#download
Is the RBR a retail unit or did you get it from an ISP by chance?
chaituphani wrote:The download you mentioned above is for RBK352 whereas I have RBR350
