chaituphani
Jul 30, 2025Aspirant
Parental control for Orbi router RBR350
Hi, I cannot see parental control tile on my orbi app (version 2.45.1.4740 The router firmware version is V4.20.0.4 Can someone please help me. Also the block sites security does not work. ...
CrimpOn
Aug 18, 2025Guru - Experienced User
Parental Controls were developed because the features in WiFi routers (such as Block Sites) no longer "do the job". My experiments showed that Block Sites works only with web sites that are http (not https) and thus are ineffective in today's world.
Congratulations on having an ISP that will respond. Most say, "your router. not my problem."
The question posed by FURRYe38 is significant. If the Orbi came from an authorized Netgear reseller, it should run the stock firmware. In some cases over the years, ISPs have provided Netgear WiFi routers and installed their own firmware. Customers were frustrated when the ISP never released firmware updates and the stock Netgear firmware would not install.
How did you get this Orbi system?
