Azevan
Dec 18, 2024Aspirant
Parental Controls and Invalid Certificate Error - CBR750
With parental controls enabled, all devices connected to the router report “untrusted or invalid certificate” when attempting to access the internet. Disabling parental controls on the router clears t...
Azevan
Dec 19, 2024Aspirant
To clarify, the browsers report a site redirect is attempting to steal your information and local host is using untrusted certificate. See another attached screenshot after clicking “show certificate”.
KevinLiT
Dec 19, 2024NETGEAR Moderator
Hello Azevan,
Thank you for providing the requested information!
Please turn on parental controls, then reset the network settings on your iOS and macOS systems and rejoin your Orbi network.
Please keep me updated to the progress on this issue!
Best,
Kevin
Community Team
- AzevanDec 20, 2024AspirantThis suggestion didn’t work. This morning again every WiFi enabled device trying to connect to the internet gives an error. TV, phones, computers, gaming consoles, etc. Disabling parental controls on the router resolves internet issues immediately. After a couple hours, parental controls can be re-enabled without issue until the next morning when the cycle repeats. The attached screenshot is an example of the error messages received. Everything points back to the untrusted certificate issued by the router included in previous posts.
