mlyang3
Sep 03, 2025Aspirant
parental controls no longer working
I need some help into figuring out why parental controls has stopped working. Even when I'm matching ip address to the correct laptop, pausing the internet via the app, the laptop continues to work. ...
Sep 03, 2025Guru - Experienced User
What NG router do you have?
What app are you using to configure Parental Controls?
What mobile platform are you using?
Be sure to disable any MAC Address randomizers on phones and pads while at home:
NETGEAR Mobile Applications and Android/Apple/Windows Devices FAQ | NETGEAR Communities
- mlyang3Sep 03, 2025Aspirant
I have a RAX54v2 and has always been using the nighthawk app to control all the devices. Everything has worked well until about a month ago when I noticed the kids were always on their devices without the time limits. I thought they were messing with the app, renaming devices, or changing their ip addresses somehow. I have their computer set to private home computer and the limit ip tracking turned off on their ipads. I use to be able to even pause the tv and that also stopped working so it’s all across the board and not just the kids’ devices. I’ve rebooted the router and deleted and added the app back on but it still doesn’t work.
