Katinka1975
Jan 05, 2026Aspirant
Parental Controls not working (post trial period)
Hi I want to continue using Parental Controls but after the trial period the button to activate a subscription has disappeared and it seems to be the only way to set it up. Anyone can help? According...
Jan 05, 2026Guru - Experienced User
Which product is this for? Nighthawk or Orbi?
Check the My Subscriptions section of the NH or Orbi app?
Katinka1975
Jan 11, 2026Aspirant
I keep getting the Message that the „smart parent control activation“ has failed -what do I do?
- FURRYe38Jan 12, 2026Guru - Experienced User
Submit a bug report thru the app:
How do I submit a bug report or logs from the Nighthawk or Orbi app? | NETGEAR Communities
Make contact with NG support.
