Helppls
Aug 26, 2024Aspirant
Rax36
Smart parental controls
internet stopped working on August 21st. Not sure if it was modem or wifi router. Unplugged both and then internet came back on. Since that time parental controls don’t work. It’s showing 0 hours used, no history, no bedtime stoppage, and pause doesn’t work either. Firmware is up to date, app is up to date. Have rebooted twice and have also loaded app onto another device. I’ve paid for a full year of this, school,starts next week. Please help
Try a factory reset and setup from scratch using a wired PC and web browser:
https://kb.netgear.com/22697/How-do-I-install-my-NETGEAR-router-using-the-router-web-interface
https://kb.netgear.com/9665/How-do-I-perform-a-factory-reset-on-my-NETGEAR-router
Or use the ERASE button on the routers web page to factory reset the router:
https://kb.netgear.com/24233/How-do-I-erase-the-configuration-settings-on-my-Nighthawk-router
- HelpplsAspirant
Coincidentally same day they updated the iOS app
Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/t5/Nighthawk-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220015/jump-to/first-unread-messageHas a power off for 1 minute then back ON with the ISP modem and router performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.- HelpplsAspirant
The restart didn’t work. Neither did the changes to MAC addresses
Modem is Cisco dpc 3008. And is the same modem we had last week when it was working Provider is CogecoThanks for your help- FURRYe38Guru - Experienced User
