duhuf
Aug 03, 2026Tutor
Can't connect to vpn services during parental controls!!
Recently,I turned on the parental control.It looks good but not friendly for vpn because the feature will stop my vpn connections even i have set it unlimited.what should i do to tackle this issue ex...
duhuf
Aug 05, 2026Tutor
Android/ios
Aug 06, 2026Guru - Experienced User
duhuf wrote:Android/ios
Ok. The profile is determined by the mac address of the phone/tablet. I'd begin by setting both devices to use the hardware mac address (and update the profile selection in the router to match that mac address). Then see if that helps.
