Novata
Jul 09, 2023Aspirant
Configuración Nas
Se ha desconfigurado el Nas que tengo, empezó con problemas con ReadyCloud con el problema Http502 y sin permitir acceso a la.nube.Ahora no coge la IpAsignada .Desde Ingishts pretendo cambiarla y no l...
michaelkenward
Jul 09, 2023Guru - Experienced User
Novata
I had problems with my RN2304 NAS.Yesterday I had problems with readycloud, the user was not valid, and also admin access. I suspect of an attack. For safety reasons, I had to reset to factory settings to recover admin page and access to server. Now I can not find it in my net and set new admin access etc... What a mess!Thanks for your help!!!
- michaelkenwardJul 09, 2023Guru - Experienced User
Netgear has withdrawn ReadyCloud from its routers. You can no longer use it for remote access to USB storage.
Support for ReadyCLOUD feature ends spring 2023 | Answer | NETGEAR Support
I don't know how this affect NAS. This is the wrong place to ask about that.
