JorgeTC's avatar
JorgeTC
Recover data from ReadyNAS RAID1 with chassis and one disk faulty
Hi all,
I have a ReadyNAS duo v2 with 2TB disks in RAID1. One of the disks has been broken and the other is not accesible from the ReadyNAS web interface, the only one option I have is to format the disk to being recognized again and I think that would destroy all my data.
I have installed the "healthy disk" in a PC with Gparted / Debian OS and I firstly saw 5 partitions SDA1, SDA2, SDA3, M126 and M127. I succesfully mounted the partition M126 and I see my folder estructure but there is nothing in it. I check the data is stored in the SDA3 partition wich has 1,8TB of capacity but at first time Gparted recognized it as unknow file system.
Running "testdisk" has recognized that unknown file system as a LVM partition but trying to examine it with MDADM says that there is no md superblock detected.
root@debian:/# mdadm --examine /dev/sda3
mdadm: No md superblock detected on /dev/sda3.
I tried other options like vgscan but there is no output for this command.
root@debian:/# vgscan -v
No volume groups found.
Here is more other information.
root@debian:/# sudo fdisk -l
Disk /dev/sda: 1,82 TiB, 2000398934016 bytes, 3907029168 sectors
Disk model: WDC WD20EARX-00P
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disklabel type: gpt
Disk identifier: 00000000-0000-0000-0000-000000000000
Device Start End Sectors Size Type
/dev/sda1 64 8386607 8386544 4G Linux RAID
/dev/sda2 8388672 9437231 1048560 512M Linux RAID
/dev/sda3 9439296 3907024799 3897585504 1,8T Linux LVM
Disk /dev/md127: 511,99 MiB, 536858624 bytes, 1048552 sectors
Disk /dev/md126: 4 GiB, 4293906432 bytes, 8386536 sectors
What I should do to successfully mount the SDA3 partition wich has the data stored?
Thanks in advance to all,
  • Simplemente me faltaba reiniciar el sistema operativo con la nueva tabla de particiones creada con la herramienta "testdisk".
    Una vez reiniciado el comando vgscan ya reconoce el volúmen LVM y con los siguientes comandos logro montar la partición y visualizar toda la información existente en el disco:
    # vgscan
    # vgchange -a y
    # mount /dev/c/c /mnt
     Saludos,
  • RaoD's avatar
    RaoD
    NETGEAR Employee Retired
    Hola JorgeTC,
    ¡Bienvenido en la Community NETGEAR!
    Le pediría amablemente que reescribiera la publicación en español.
    La Comunidad nació como un lugar de intercambio, experiencias y soluciones, en beneficio de todos los usuarios registrados.
    Un post en inglés, en la Comunidad española, limitaría esta función.
    Gracias de antemano por su amable cooperación.
    Raony
    Equipo de NETGEAR
    • JorgeTC's avatar
      JorgeTC
      Mil disculpas, confusión mía al pensar que era un foro en inglés.
      Tengo un ReadyNAS duo v2 con discos de  2TB en RAID1. Uno de los discos se ha averiado y el otro no está accesible desde la interfaz web del ReadyNAS, la única opción que tenía era formatear el disco con lo que pienso que se destruiría toda la información alojada en el mismo.
      He instalado el disco sano en un PC con Gparted / Debina OS y observo 5 particiones SDA1, SDA2, SDA3, M126 y M127. Compruebo que la información está alojada en la partición SDA3 la cuál tiene 1,8TB de capacidad pero Gparted la reconoce como "unknown filesystem".
      Con el comando "testdisk" se reconoce la partición como un volumen LVM pero con comandos MDADM se especifica que no detecta MD superblock.
      Disklabel type: gpt
      ¿Como puedo montar satisfactoriamente SDA3?
      Model: RND2000v2|ReadyNAS Duo v2 Chassis only
      • JorgeTC's avatar
        JorgeTC
        # vgscan
        # vgchange -a y
         Saludos,
