ArturoTEKNO
Mar 28, 2023Aspirant
Extensor de Rango para N300 WNR2000v5
Buenas, quería saber cual extensor de Rango me recomendaríais para un N300 WNR2000v5
- ArturoTEKNOAspirant
Sorry
I would like to know which range extender would you recommend for a N300 WNR2000v5
I wouldn't.
The WNR2000 is a very low performing n300 device.
Before adding a range extender, I'd upgrade the router to something from the current generation.
You'll get a bit better range and a lot more performance.
then if the new router doesn't reach, I'd look at a range extender .
Or I'd just start with a mesh system if you know you'll need more range.
Thanks
