KANNI_Port
Jun 29, 2020Tutor
I have XR700 and i want to use xr700 as my router in my home
Hi,
I have XR700 and i want to use xr700 as my router in my home. I am from Portugal and i saw that ASUS as a Firmware to use ASUS routers instead of operators router.
My operator is MEO in ...
Netduma-Fraser
Jun 30, 2020NetDuma Partner
We don't have specific firmware versions for different ISPs. What requirements do you need to obtain a straight connection without the ISP router? PPPoE, VLAN, DHCP 60/61?
KANNI_Port
Jun 30, 2020Tutor
I can putt router operator on bridge mode that allows me to gain control on Netgear router.
how do i do PPPoE, VLAN, DHCP 60/61? Whats the difference between them?
Regards
- Netduma-FraserJun 30, 2020NetDuma PartnerYes you can do that easily. I was just wondering if there is a specific kind of connection method that you need but it sounds like you can obtain a connection without them already so thats good!
- KANNI_PortJul 01, 2020Tutor
So, How do i configure any of those connections on XR700?
I have 1000Mbs/400Mbs download/upload and on PS4 i can't have a constant connection
Sometimes 350/20mbs them 50/10... but most of the time under 60/20mbs.
I don't understand how do this happen, because in my pc when i test it always gives me close 100/100mbs because my pc net board is 100/100mbs.
But in Ps4 is 1gb net board. So uncostant.
Playing against players from other contries like UK they move faster then me, it is so fustrating
