KANNI_Port
Jun 29, 2020Tutor
I have XR700 and i want to use xr700 as my router in my home
Hi,
I have XR700 and i want to use xr700 as my router in my home. I am from Portugal and i saw that ASUS as a Firmware to use ASUS routers instead of operators router.
My operator is MEO in ...
KANNI_Port
Jun 30, 2020Tutor
I can putt router operator on bridge mode that allows me to gain control on Netgear router.
how do i do PPPoE, VLAN, DHCP 60/61? Whats the difference between them?
Regards
Netduma-Fraser
Jun 30, 2020NetDuma Partner
Yes you can do that easily. I was just wondering if there is a specific kind of connection method that you need but it sounds like you can obtain a connection without them already so thats good!
