KANNI_Port
Jun 30, 2020Tutor
I have XR700 and i want to use xr700 as my router in my home
Hi,
I have XR700 and i want to use xr700 as my router in my home. I am from Portugal and i saw that ASUS as a Firmware to use ASUS routers instead of operators router.
My operator is MEO in ...
KANNI_Port
Jul 02, 2020Tutor
I have 1000Mbs/400Mbs download/upload and on PS4 i can't have a constant connection
Sometimes 350/20mbs them 50/10... but most of the time under 60/20mbs.
I don't understand how do this happen, because in my pc when i test it always gives me close 100/100mbs because my pc net board is 100/100mbs.
But in Ps4 is 1gb net board. So uncostant.
Playing against players from other contries like UK they move faster then me, it is so fustrating
bacevedo
Jul 02, 2020NETGEAR Employee Retired
The PS4 is pretty notorious for it's network card. Until the Pro Edition the PS4 couldn't connect to 5 GHz WiFi. The best solution for connecting with a PS4 is wire it to the router.
- Netduma-FraserJul 02, 2020NetDuma PartnerThe PS4 speed test is not entirely accurate but you have plenty of bandwidth for gaming so that's not an issue. I'd recommend going through our optimal settings guides: http://support.netduma.com/en/support/solutions/folders/16000090646
- KANNI_PortJul 03, 2020Tutor
Ok. thanks. i will take a look.
yes my ps4 is connected by cable.
I'm testing DNS server on "DNS BenchMark" and in different tests with different DNS
It says that : One or more of this system's 3 nameservers are dead!
Although the whole point of having multiple redundant DNS resolving nameservers is to have a reliable source of DNS lookups, any nameservers that actually are dead and not replying to DNS queries can seriously hamper a system's performance as it waits for the dead nameserver to reply before trying to use its backup nameservers. Therefore, removing any persistently dead nameservers is always a good idea.I think that:
When i change DNS server in SX10 the router operator blocks DNS changes.
- Netduma-FraserJul 03, 2020NetDuma PartnerHave you made the DNS changes on the router also as you will need to do that.
