Yorchi
Jan 10, 2024Aspirant
Netgear r7800 - control de accesos
Resulta, que tengo un netgear r7800, y siempre ha funcionado bien, pero desde hace un tiempo, llevo peleando a ver si consigo saber por qué me pasa esto. La cuestión, es que, tengo el control de ...
- Jan 10, 2024
It turns out, I have a Netgear R7800, and it has always worked well, but for some time, I have been fighting if I know why this happens to me.
The question is that, I have activated access control and thus filter by Mac, all devices that connect to my network. But every time the router restarts for anything, access control is deactivated and I have to activate it manually.
I have a friend who has this same router and this does not happen, with the same version.
I have already tried to restore factory, to change firmware version, to put OPENDWRT to return to stock firmware, in case some configuration had been left hanging, etc. I don't know what else to try.
Any idea how could this be solved?
Thank you
Yorchi
Thank you
