K3NU5
Apr 30, 2024Follower
Inyector Poe para Netgear wifi 6 AX1800 Access Point WAX610
Hola, ¿que inyector poe es recomendable usar para alimentar un punto de acceso Netgear wifi 6 AX1800 Access Point WAX610?
Any industry standard PoE+ injector compliant to IEEE 802.3at (or even PoE++ 802.3bt) able to provide 30W or more, where PoE++ does start at 45W [what is not required for the WAX610] on the PSE (Power Source Equipment).
Not workable are the many often inexpensive "passive" (proprietary) PoE injectors, often offered for 24V or 48V, and standards compliant PoE injectors supporting only IEEE 802.3af / at PoE-compatible PDs (Powered Devices) with a maximum of 15.4W at the PSE, resp. only 12.95W at the PD, as this isn't sufficient for the WAX610 - these might appear workable, but reduced to a 1x1 radio only.
- MartaRNETGEAR Employee
Hola K3NU5
¡Bienvenido a la Community NETGEAR! 😊
Tal y como dice Schumaku, el dispositivo WAX610 require de 15.3W, de forma que necesitará PoE+ como mínimo, ya que proporcionan 30W. Desde Netgear no podemos dar recomendaciones sobre productos de otras compañías.
Que tenga un buen día.
Saludos,
Marta R
Equipo de NETGEAR
