jmahecha88
Apr 16, 2025Follower
Hola! Tengo un Netgear GS724T-v4, este dispositivo cuenta con tabla de IP de los dispositivos que i?
Me gustaria saber si el Netgear GS724T-V4 tiene la opcion de mostrar las IP de los equipos que tiene conectado, lei en el manual y me indica que en las siguientes ventanas: Seleccionar Sistema > LLD...
MartaR
Apr 17, 2025NETGEAR Employee
Hola, jmahecha88
¡Bienvenido a la Community NETGEAR! 😊
El modelo GS724Tv4 es un switch de capa 2, así que no maneja direcciones IP, sólo MAC.
¿Necesita alguna cosa más?
Que tenga un buen día.
Saludos,
Marta R
Equipo de NETGEAR
schumaku
Apr 17, 2025Guru - Experienced User
Hola MartaR
Afraid, this does not depend on the switch capabilities, even on a L3 capable switch: The LLDP-MED data is provided from the connected device! Certainly for these two Biamp devices (the Tesira Forté, or the media device, don't have an option to provide additional alternate LLDP-MED including e.g. the IP address, so the LLDP-MED data is limited to what you see on the screenshot.
Sorry for replying in English.
-Kurt.
- MartaRApr 21, 2025NETGEAR Employee
Hi, schumaku
Yes, LLDP is in itself a layer 2 protocol to see connected devices, such as CDP in Cisco. However, we wanted to check if there was an IP table available, which, unfortunately, there is not for this model, as it's a layer 2 switch.
Thank you very much for your assistance.
Marta.
Netgear team.
