PouClar
Feb 22, 2022Aspirant
Ayuda configuración Switch GS716Tv3
Buenos días, primero que nada presentarme: soy profesor de un centro de educación secundaria y acudo a la comunidad Netgear solicitando ayuda. La cuestión es la siguiente: tenemos un Switch GS716Tv...
- Feb 24, 2022
Start your adventure on the switch here https://www.netgear.es/support/product/GS716Tv3.aspx
Firmware downloads are under [Descargas] https://www.netgear.es/support/product/GS716Tv3.aspx#download remember the firmware is coming in a zip which needs to be expanded (two files, firmware archive and some release notes).
https://www.downloads.netgear.com/files/GDC/GS716TV3/GS716Tv3_GS724Tv4_GS748Tv5_SWA_25Sept2013.pdf - p. "HTTP File Upload" - Maintenance > Upload > HTTP File Upload You can upload the firmware image (nickname "Archive") into the image1 section for simplicity, because your system is new, and the image1 is defined as the default boot section. (yes, all confusing for historical reasons ref. up- vs. download for example)
Documentation is available on [documentación] https://www.netgear.es/support/product/GS716Tv3.aspx#download (except from the installation guide it's all in English only when I have it right).
Regards
-Kurt (from Switzerland)
PS. My Spanish is very limited, reading is ok - but no chance to write something meaningful 8-)
schumaku
Feb 23, 2022Guru - Experienced User
There is not much required for a simple set-up - you don't need to grab any kind of pre-made configurations:
- Firmware update
- Set a strong password
...and up you go to start with!
PouClar
Feb 23, 2022Aspirant
Buenos días, primero que nada darte las gracias por contestar.
Creo que este Switch es gestionable, y según tus indicaciones, si actualizo el Firmware no necesito ningún tipo de configuración para funcionar. He entendido bien?
Si esto es así, puede indicarme la pestaña donde se actualiza el Firmware cuando accedo al mismo? Descargo el nuevo Firmware de Netgear.com?
Muchas gracias por tu ayuda.
Saludos
- schumakuFeb 24, 2022Guru - Experienced User
Regards
- RaoDFeb 24, 2022NETGEAR Employee Retired
Hola PouClar,
¡Bienvenido en la Community NETGEAR!
Le aconsejo en seguir todas la indicaciones que le ha dado el usuario schumaku.
Como primer paso, si necesario, tiene que actualizar el dispositivo con el último firmware disponible.
Y luego tiene todas las informaciones para configurar su dispostivo en las Guías de usuario y documentación que encuentra en la pagina de soporte de GS716Tv3, último enlace proporcionado. :)
Gracias schumaku por ayudar la Community! :)
Saludos,
Raony
Equipo de NETGEAR- PouClarMar 03, 2022Aspirant
Buenos días,
he seguido todos los pasos y me ha quedado solucionado.
Gracias
