Pat49's avatar
Pat49
screenshot Netgear A 6150 wifi
hello, I would like my iPad to be able to serve as a screenshot of my PC. Is this possible using Netgear A6150 wifi? If so, how should we do it. Thank you for your help.
(NETGEAR A 6150 Wifi)
  • michaelkenward's avatar
    michaelkenward
    Screenshot? What does that mean? What are you trying to do?
    The A6150 is a USB adapter. It allows you to connect a PC to wifi.
    • Pat49's avatar
      Pat49
       want my tablette to serve as a repaeter when  i drive my Sailing Boat while my PC remains on the chart table inside
        michaelkenward
        Sounds complicated. Not the sort of application that comes naturally to domestic network devices.
        More like something I would expect bluetooth to handle.
        What is the tablet? iOS? Windows? Android?
        What is the PC? MacOS? Windows?
        Where is the Internet connection coming from?
