Sylvester2999's avatar
Nov 15, 2017
R7800 configuration Freebox & Nas syno sur 2 reseaux
Bonjour        ,     Est-il possible d’acceder à un Nas Synology sur 2 reseaux ? Le reseau 192.168.0.x pour serveu...
  • antinode's avatar
    antinode
    Nov 16, 2017
    > Je n'ai rien modifié dans la configuration de R7800
       That is expected.  The R7800 does not need any new information.
    Any message to a foreign subnet gets sent out through its WAN port.
    > Je n'ai RIEN ajouté dans les redirections de la Freebox
       Ah, yes.  If the connection is made by a client on the R7800 LAN,
    then NAT (on the R7800) may do everything you need.  The Freebox will
    see a connection coming from the R7800 WAN interface (192.168.0.2).  It
    will reply to that, and NAT on the R7800 will pass the reply to the real
    client on the R7800 LAN.
       If the connection is to be made by a client on the Freebox LAN,
    _then_ the Freebox will need a static route to the R7800 LAN.
    (Otherwise it would send the message to your ISP.)
       So, in one direction (R7800 -> Freebox), NAT solves the problem.  In
    the other direction (Freebox -> R7800), the route is required.  Sorry
    for the (my) confusion.
