Regis57's avatar
Regis57
Tutor
Oct 10, 2022
Routeur R7800 - problème redémarrage fréquent.
Bonsoir depuis quelques jours j'ai un soucis avec mon #R7800 configuré en routeur, en effet une à deux fois par heure je perd l'internet et le routeur redémarre seu
J'ai d'abord pensé que c'était mon fournisseur fibre qui avait des soucis, mais si je branche mon pc en direct au moment de la coupure cela fonctionne, le problème vient donc du r7800.
Dans le journal j'ai des message bizarres "[DoS Attack: Ping Sweep] from source: 213.166.201.106, Monday, October 10, 2022 20:10:24" qui se répètent à chaque panne.
Quelqu'un d'entre vous peut il m'aider ?
extrait journal :
[admin login] from source 192.168.1.105, Monday, October 10, 2022 20:31:36
[DoS Attack: SYN/ACK Scan] from source: 194.67.203.60, port 8428, Monday, October 10, 2022 20:31:15
[DHCP IP: 192.168.1.23] to MAC address 8c:85:80:83:cf:d6, Monday, October 10, 2022 20:31:04
[DHCP IP: 192.168.1.2] to MAC address 02:0f:b5:92:f0:42, Monday, October 10, 2022 20:31:04
[DHCP IP: 192.168.1.2] to MAC address 02:0f:b5:92:f0:42, Monday, October 10, 2022 20:30:44
[DHCP IP: 192.168.1.2] to MAC address 02:0f:b5:92:f0:42, Monday, October 10, 2022 20:30:41
[DoS Attack: ACK Scan] from source: 213.166.201.16, port 443, Monday, October 10, 2022 20:30:31
[DHCP IP: 192.168.1.2] to MAC address 02:0f:b5:92:f0:42, Monday, October 10, 2022 20:30:20
[DHCP IP: 192.168.1.3] to MAC address 02:0f:b5:a2:7c:bd, Monday, October 10, 2022 20:29:58
[DHCP IP: 192.168.1.2] to MAC address 02:0f:b5:92:f0:42, Monday, October 10, 2022 20:29:57
[DHCP IP: 192.168.1.2] to MAC address 02:0f:b5:92:f0:42, Monday, October 10, 2022 20:29:45
[DoS Attack: ACK Scan] from source: 18.195.145.6, port 443, Monday, October 10, 2022 20:29:44
[DHCP IP: 192.168.1.11] to MAC address 70:5f:a3:b7:ce:6b, Monday, October 10, 2022 20:29:40
[DoS Attack: ACK Scan] from source: 159.100.4.212, port 443, Monday, October 10, 2022 20:29:31
[DHCP IP: 192.168.1.5] to MAC address 9e:c9:eb:19:d9:de, Monday, October 10, 2022 20:29:27
[DHCP IP: 192.168.1.5] to MAC address 9e:c9:eb:19:d9:de, Monday, October 10, 2022 20:29:26
[DHCP IP: 192.168.1.20] to MAC address da:61:e4:93:a9:04, Monday, October 10, 2022 20:29:25
[DoS Attack: SYN/ACK Scan] from source: 194.67.203.60, port 65043, Monday, October 10, 2022 20:29:19
[DHCP IP: 192.168.1.5] to MAC address 9e:c9:eb:19:d9:de, Monday, October 10, 2022 20:29:15
[DoS Attack: ACK Scan] from source: 18.195.145.6, port 443, Monday, October 10, 2022 20:29:14
[DoS Attack: Ping Sweep] from source: 3.75.206.190, Monday, October 10, 2022 20:29:11
[DHCP IP: 192.168.1.2] to MAC address 02:0f:b5:92:f0:42, Monday, October 10, 2022 20:29:10
[DHCP IP: 192.168.1.23] to MAC address 8c:85:80:83:cf:d6, Monday, October 10, 2022 20:28:58
[DHCP IP: 192.168.1.105] to MAC address 40:61:86:60:61:21, Monday, October 10, 2022 20:28:57
[DoS Attack: ACK Scan] from source: 18.195.145.6, port 443, Monday, October 10, 2022 20:28:43
[Time synchronized with NTP server] Monday, October 10, 2022 20:28:28
[Internet connected] IP address: 100.127.15.226, Monday, October 10, 2022 20:28:27
[Initialized, firmware version: V1.0.2.90] Monday, October 10, 2022 20:28:21
merci
cordialement
  • PatrycjaG's avatar
    PatrycjaG
    NETGEAR Moderator
    Bonjour Regis57,
    Bienvenue sur la communauté Netgear 🙂
    Avez-vous des appareils abonnés à des services qui doivent être renouvelés ?
    Combien d'appareils sont branchés au réseau du routeur ?
    Cela concerne les appareils connectés en Wifi ou par câble ?
    Quelle est la version du firmware du R7800 ?
    Bonne journée,
    Patrycja
    Equipe Netgear
      PatrycjaG
      NETGEAR Moderator
      Bonjour Regis57,
      "Avez-vous des appareils abonnés à des services qui doivent être renouvelés ?" par cela je veux dire qu'il y a des appareils qui peuvent être abonnés à des services comme par exemple des antivirus qui nécessitent d'être renouvelés. Dans ce cas, le routeur peut bloquer les sources entrantes et non fiables.
      Bonne journée,
      Patrycja
      Equipe Netgear
    • Regis57's avatar
      Regis57
      Tutor
      pour la question "Cela concerne les appareils connectés en Wifi ou par câble ?" c'est le routeur qui est attaqué et après quelques minutes il disjoncte et reboute. Les voyants s'éteignent et il repart.
      Du coup oui tout est coupé WIFI et filaire.
    • Regis57's avatar
      Regis57
      Tutor
      Je ne comprend pas bien la question "Avez-vous des appareils abonnés à des services qui doivent être renouvelés ?"
      cordiaement
