Jedediah
Nov 30, 2023Aspirant
GS752TPv2 - Port GigabitEthernet39 moving from Forwarding to Disabled
Hello, We have these logs on multiples ports of our switches and I can't figure out what could cause this issue : Switches are in a near factory default state, so RSTP is enabled. The t...
schumaku
Nov 30, 2023Guru - Experienced User
Jedediah wrote:
Switches are in a near factory default state, so RSTP is enabled. The topology is pretty simple : ISP router > SW01 > SW02. Untagged VLAN 1 on each port and one tagged VLAN on each port for TOIP.
All cables are brand new and the devices plugged into those ports are only Dell computers.
Nope - on port 32 there is almost certainly a Dell switch with some STP support up and active.
MAC prefix/OUI: 08:92:04, Note: Dell, Unicast MAC address, universally administered addresses (UAA)
Jedediah
Hello 🙂
There is no Dell switch on the network.
This is a Dell workstation or a Dell docking station.
Améliorez vos compétences avec la Netgear Academy - Formez-vous, certifiez-vous et restez à la pointe de la technologie Netgear !
Rejoignez-nous!
