Packito
Sep 30, 2023Tutor
Pas d'internet avec Wifi Guest sur AP WAX214
Bonjour, Mon point d'accès Netgear est relié à un routeur via Ethernet POE et est configuré avec 2 SSID dont 1 en tant qu'invité sur un réseau LAN dans une TPE. Je me connecte sans soucis sur le SS...
- Oct 01, 2023
A little bit to thin information, how is your WAX214 connected to your LAN (keep in mind I don't know anything about the French livebox devices)?
Here in my LAN, the WAX214 is connected to the usual network (either by DHCP, or here for my test simplicity on a static IP):
Now, how is the guest network configured - with a [x] to be a Guest Network, making up an isolated IP subnet, just for the wireless guests, NATed many to one on the WAX214 LAN IP? In this example, I have set security to OWE, to allow anyone accessing this SSID and the guest network. Note this 192.168.200.1/24 network is known on the WAX214 only::
With this config, the wireless test client does get an IPv4 address assigned to this isolated 192.168.200.1/24 subnet, and it can reach the world (Internet) - just as I'm editing the post here currently:
Or do you have mapped the SSID without ticking the Guest Network, but mapped it to a VLAN, here the LAN basic VLAN 1?
Does this help?
schumaku
Oct 01, 2023Guru - Experienced User
Does this help?
- PackitoOct 07, 2023Tutor
Hi Schumaku
Thank you for your reply
I think I must change DNS address 192.168.1.1(router IP) to 8.8.8.8 and 8.8.4.4 on WAX214
I will do it and tell
Regards
Packito
Améliorez vos compétences avec la Netgear Academy - Formez-vous, certifiez-vous et restez à la pointe de la technologie Netgear !
Rejoignez-nous!
