wizhack
Apr 06, 2016Aspirant
Problèmes avec update transmission
Bonjour voulant mettre à jour transmission je décide de télécharger le .deb dispo sur github pour l'architecture du nas (arm). Je commence par désinstaller via l'interface web l'ancienne version de ...
wizhack
Apr 08, 2016Aspirant
Hi i tried both solutions the i get this errors
# dpkg -r transmission (Reading database ... 13864 files and directories currently installed.) Removing transmission ... Failed to issue method call: Unit fvapp-transmission.service not loaded. dpkg: error processing transmission (--remove): subprocess installed pre-removal script returned error exit status 1 Errors were encountered while processing: transmission # dpkg --purge transmission (Reading database ... 13864 files and directories currently installed.) Removing transmission ... Failed to issue method call: Unit fvapp-transmission.service not loaded. dpkg: error processing transmission (--purge): subprocess installed pre-removal script returned error exit status 1 Errors were encountered while processing: transmission
wizhack
So, i found how to remove
with the help of debian-fr forum here is the thread in french
https://www.debian-fr.org/t/probleme-de-maj-transmission/69076/22
You need to comment every line in /var/lib/dpkg/info/transmission.prem just let the last exit 0 without #
I think the build have a problem when i try to reinstal the *.deb file i have the same errors, but when i reinstall transmission throught the readynas "appcenter" it works, so if you have any ideas to update transmission , im your man ;) !
- super_poussinApr 12, 2016Virtuoso
take the version in my community dropbox :)
- wizhackApr 13, 2016Aspirant
Super !!! du coup en installant la version sur ton dropbox tout a marcher à la perfection !!!
Améliorez vos compétences avec la Netgear Academy - Formez-vous, certifiez-vous et restez à la pointe de la technologie Netgear !
Rejoignez-nous!
