phg74
Apr 20, 2018Aspirant
ReadyNAS Ultra 6 in X-RAID2; SMB crashed with out of memory in Kernel Log
Hello. I have a ReadyNAS Ultra 6 that was in 4.2.15. I upgrade first to 4.2.31 and second to 6.9.3 After the factory reset, I have all my disks OK and the size OK. Then I launch several command...
mdgm-ntgr
Apr 21, 2018NETGEAR Employee Retired
OOM errors mean that there's insufficient memory so services have had to be killed.
This may suggest that you're trying to run too many services/apps, that there's a memory leak of some kind or that you may benefit from an unsupported memory upgrade using 3rd party memory.
All our x86_64 models that shipped with OS6 shipped at least 2GB RAM. The Ultra 6 shipped with 1GB RAM.
Améliorez vos compétences avec la Netgear Academy - Formez-vous, certifiez-vous et restez à la pointe de la technologie Netgear !
Rejoignez-nous!
