diamondminer
Jun 01, 2016Aspirant
Model: ReadyNAS Ultra 2 [X-RAID2]
I have a ReadyNAS Ultra 2 [X-RAID2] That I would like to use ReadyNAS Remote on it but I don't which download you use.
Here is the choice, what do I doanload?
Step 2 – Install ReadyNAS Remote add-on on the ReadyNAS
If the ReadyNAS Remote add-on is not already installed on your ReadyNAS, download the add-on for your ReadyNAS model here:
ReadyNAS Remote add-on for ReadyNAS Duo/NV+/1100/600/X6
ReadyNAS Remote add-on for ReadyNAS NVX/Pro/2100/3100/3200/4200
Thanks
Hello diamondminer,
You are using an Intel or x86-based ReadyNAS OS4, so that should be ReadyNAS Remote add-on for ReadyNAS NVX/Pro/2100/3100/3200/4200.
See How to setup remote access with ReadyNAS Remote article.
- StephenBGuru - Experienced UserThe ReadyNAS Remote add-on for ReadyNAS NVX/Pro/2100/3100/3200/4200 choice is the binary for 4.2.x systems.
- diamondminerAspirant
Thank you for your help!
- JennCNETGEAR Employee Retired
Hello diamondminer,
Hello diamondminer,
You are most welcome!
Please feel free to post any comments, suggestions or questions. We appreciate your contribution to the community!
