diamondminer
Jun 01, 2016Aspirant
Model: ReadyNAS Ultra 2 [X-RAID2]
I have a ReadyNAS Ultra 2 [X-RAID2] That I would like to use ReadyNAS Remote on it but I don't which download you use. Here is the choice, what do I doanload? Step 2 – Install ReadyNAS Remot...
- Jun 02, 2016
Hello diamondminer,
You are using an Intel or x86-based ReadyNAS OS4, so that should be ReadyNAS Remote add-on for ReadyNAS NVX/Pro/2100/3100/3200/4200.
See How to setup remote access with ReadyNAS Remote article.
Jun 02, 2016Guru - Experienced User
The ReadyNAS Remote add-on for ReadyNAS NVX/Pro/2100/3100/3200/4200 choice is the binary for 4.2.x systems.
diamondminer
Jun 03, 2016Aspirant
Thank you for your help!
