diamondminer's avatar
diamondminer
Model: ReadyNAS Ultra 2 [X-RAID2]
I have a ReadyNAS Ultra 2 [X-RAID2]  That I would like to use ReadyNAS Remote on it but I don't which download you use.   Here is the choice, what do I doanload?   Step 2 – Install ReadyNAS Remot...
  • JennC's avatar
    Jun 02, 2016
    Hello diamondminer,
    You are using an Intel or x86-based ReadyNAS OS4, so that should be ReadyNAS Remote add-on for ReadyNAS NVX/Pro/2100/3100/3200/4200.
    See How to setup remote access with ReadyNAS Remote article.
ProSupport for Business
