Neuvidor
Sep 22, 2018Aspirant
RN312 - Récupérer les données
Bonjour, J'ai depuis une semaine un problème avec mon ReadyNAS RN312. Le problème a commencé avec le partage de dossier, impossible d'accéder aux dossier depuis mes différents PC windows. L'interface...
Neuvidor
J'ai remarqué que ma partition dev\md0 de 4Go est saturée, il ne reste que 640ko de dispos. Le problème peut-il venir de là ?
J'ai fait un Os-Reinstall hier soir depuis le boot menu et depuis un peu d'amélioration. C'est à dire que le NAS arrive à booter partiellement. L'application Web PLEX fonctionne à nouveau mais impossible d'ouvrir la page d'administration Web.
Neuvidor
Oct 12, 2018Aspirant
HELP !!!
I have a ReadyNas 312 which is warranty until 5th of february 2019.
There is a big issue with the product but I can’t get any support from MyNETGEAR account because it’s impossible for me to register the product on my account (already registered). Unfortunately this device was a friends’s present but nobody remember who has registered the product. I called Netgear support but they refused to help me…
Effacé par la modération.
Hardware description :
- Disk A = WD red 4To (only 3To is used) => SMART is OK
- Disk B = Hitachi 3To => SMART is OK
- Partition = X-Raid2 => Mirroring
- Apps = Plex + iStat => Official apps
Current status :
- Power is blinking permanently
- "Act" led seems correspond to disks activity (the led is ON when we hear some noise from disks)
- "Disk 1", "disk 2" and "backup" led are OFF
- IP adress 192.168.1.67 gives an answer with a ping command from a windows computer
- "ReadyNAS Admin Page" on 192.168.1.67 is not available (only login page but I always get the message "Connecting to the ReadyNAS Admin Page", then I always get the message "ReadyNAS Admin Page is offline")
- "Plex" web application on 192.168.1.67 :32400/web/index.html still working fine
- All my personnal data are available in command line when I use a usb keyboard and a hdmi screen with the default account directly on the ReadyNAS
- I already performed twice OS reinstall but no changes
Question :
- How to register my ReadyNAS into myNETGEAR account ?
- How to copy my personnal data to an external usb disk ? The purpose is to save all data before a factory reset.
Remarks :
- I’m really not happy about the netgear support, phone hotline refused to help me, no answer from Netgear community even if my product is in warranty period.
- I'm really affraid about losting my data, there is 18 years of my familly pictures, that’s why I choose mirroring mode with X-RAID2 in order to have easy support from Netgear, I made a mistake...
Améliorez vos compétences avec la Netgear Academy - Formez-vous, certifiez-vous et restez à la pointe de la technologie Netgear !
Rejoignez-nous!
