joco's avatar
joco
Follower
Sep 15, 2015
150MB + on ethernet only 20MB wi-fi?
I was getting 150+ both ethernet hardwired and wi-fi and all of a sudden the wi-fi dropped down to 20MB? Any ideas of what to check?
1 Reply
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello Joco
    I would try to change the wireless channel to see if something is causing interfearance also check to see that a older wifi device isnt connected to the wireless if its using 802.11 b/g it will slow the whole wifi down. Last thing I would check is try to disable QOS if thats enabled. Hope to hear your feedback
    DarrenM
