donawalt
Apr 20, 2024Hero - Experienced User
192.168.100.10?
I noticed by looking at modem logs, that it appears my cable modem, which has an IP address of 192.168.100.1 when it is power cycled, may have a temporary IP address of 192.168.100.10 when it boots u...
donawalt
Oops typo, modem is 192.168.100.1. When it boots up it appears to for a short period of time broadcast an IP of 192.168.100.10
CrimpOn
Apr 20, 2024Guru - Experienced User
Not a short time. ALL the time. It does not "broadcast". That is simply the IP address of the management port within the modem.
Because the IP subnet created by the modem is 192.168.1.xxx, any time a device attempts to connect to any address within that IP subnet, it is expected to be found somewhere in the subnet. If the IP address is not in the subnet, then it has to go "out", which the modem will intercept.
Have you tried to connect to 192.168.100.1 ?
- donawaltApr 20, 2024Hero - Experienced User
Yes, I had a typo in my OP- the modem address is 192.168.100.1. I have tried connecting and pinging 192.168.100.10, nothing. Can we do anything with that address?
- CrimpOnApr 20, 2024Guru - Experienced User
Did you try 10 or 1?
OK - to restate the question -
192.168.100.1 WORKS - I get the modem admin page., All is good. No issues, used it for years on multiple modems.
Today I noticed 192.168.100.10 shows up on a boot up - it's in the modem log. I am trying to find out what that is. Thanks!
