Monsta715
Sep 30, 2022Aspirant
2.4 connection not working
We have a Nighthawk router and we have had a 2.4ghz and a 5G connection but all of a sudden the 2.4ghz is gone. When we called support they are saying we need to pay $129.99 a YEAR to keep that conne...
Sep 30, 2022Guru - Experienced User
What NG router model do you have?
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Monsta715
I am not super internet savvy so please bare with me.
We have a Nighthawk C6300v2 but I do not know how to check the firmware.
We did the reset after receiving your response but have not done a factory reset. We don't know how to go about that.
And we called NG back 3 times because we kept getting hung up on, basically we are exactly one year out of our warranty and they won't help us without us paying for a new warranty. So this thread is our only hope really haha.
- FURRYe38Sep 30, 2022Guru - Experienced User
Can find the FW on the modems web page using a PC and web browser at 192.168.0.1 or 192.168.100.1
Can reset the modem by pressing the reset button for 10 seconds then release or using the ERASE button on the modems web page:
- Monsta715Sep 30, 2022AspirantDid a factory reset and still no luck.
Firmware was v1.03.11 - Monsta715Oct 16, 2022AspirantIs this something you can still assist me with?
I've tried reseting the modem a second and third time but I'm not getting anything and I am unsure how to Uninstall the current firmware. I can't use any security cameras since this failure and I'm desperate for assistance- FURRYe38Oct 17, 2022Guru - Experienced User
If you reset the modem and can not access the modems web page at 192.168.100.1 or 192.168.0.1 or 192.168.1.1, I would presume the modem is bad and needs to be replaced.
