deirdreyee
Feb 12, 2021Initiate
2.4 Ghz network disappeared permanently
I purchased this router / modem 2 months ago. W set up the 2.4 Ghz and 5G connections and used both. A few days ago the 2.4 Ghz disappeared from our devices. 5 G still shows up throughout the house b...
- Aug 06, 2022
I reset it and the disappeared network name came back.
Eitzaley
Aug 06, 2022Aspirant
- FURRYe38Aug 07, 2022Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
