carreleevt
Aug 22, 2020Aspirant
2.4 GHz not working
I am not tech savy and have spent several hours trying to figure this out. I have a C3700v2 – N600 WiFi Cable Modem Router and after a reset, 2.4 GHz is no where to be found. I have several devi...
MARKNOTHANKS
Dec 15, 2020Aspirant
Same here. No 2.4, but 5 is working. Started to NOT work on 12/14/20. What gives? ISP reports everything is fine on their end.
- FURRYe38Dec 20, 2020Guru - Experienced User
Has a factory reset and setup from scratch been performed?
