carreleevt
Aug 22, 2020Aspirant
2.4 GHz not working
I am not tech savy and have spent several hours trying to figure this out. I have a C3700v2 – N600 WiFi Cable Modem Router and after a reset, 2.4 GHz is no where to be found. I have several devi...
Gamer_0224
Dec 20, 2020Tutor
So have you did the factory reset on it yet? Have you logged into the router on the setup of it. Does it even broadcast a 2.4 signal? If by chance you haven't did a factory reset I would try that. If you did and now you don't see a 2.4 signal broadcasted then you may want to log into the router and look in the options on it to see if it is enabled.
