Justin92
Apr 03, 2017Initiate
2.4 GHz on C6300 Not Working
Ok, so I've been having a weird issue regarding getting 2.4 GHz to work. When I first bought the router, both the 2.4 and 5 GHz LED was on and both were working. After awhile, only 2.4 GHz worked, and...
DarrenM
Apr 05, 2017Sr. NETGEAR Moderator
Hello Justin92
Have you tried to factory reset the unit? Also you may want to check with your ISP they may have the coding wrong on your account and its disabling wifi.
DarrenM
