Justin92
Apr 03, 2017Initiate
2.4 GHz on C6300 Not Working
Ok, so I've been having a weird issue regarding getting 2.4 GHz to work. When I first bought the router, both the 2.4 and 5 GHz LED was on and both were working. After awhile, only 2.4 GHz worked, and...
Justin92
Apr 06, 2017Initiate
Yes, I've performed a factory reset but it didn't resolve my issue. I also contacted my ISP but they told me everything is working fine on their end, and since I'm using a 3rd party router, I need to contact Netgear to resolve my issue. I then contacted Netgear and explained my issue.
The representative told me my settings are "all messed up" and she could go into my network to fix this, but I no longer have my 90 day free support so I need to pay $139 for a year of support before she can fix it. I paid $200 for this router and don't wanna fork out another $139 just to fix this issue. Any idea what settings are "all messed up?"
DarrenM
Apr 07, 2017Sr. NETGEAR Moderator
Hello Justin92
Go to Advanced-Advanced Setup-Wireless settings and make sure the 2.4ghz is checked in there.
DarrenM
