Chave
Apr 23, 2025Follower
2.4ghz band broadcasting but no internet
This is the second CAX80 I've had that has had this similar issue. The first one i returned and got a new one which then worked fine until about two days ago. The issue is that the 2.4ghz SSID will br...
Apr 23, 2025Guru - Experienced User
Are you using Smart Connect?
Is AX mode enabled on the 2.4Ghz network? Try with it disabled?
What channels are you using on the radios?
Has a factory reset and setup from scratch using a wired PC and web browser been performed?
Who is your ISP your connecting with?
