Sweetjanaya1
May 05, 2023Aspirant
2.4GHZ Band not broadcasting
My 2.4GHZ is not broadcasting it was working fine then it just disappeared. It is enabled and showing a green light on the modem
- May 05, 2023
Has a power off for 1 minute then back ON with the ISP modem and router been performed?
Turn off and unplug modem.
Turn on computers and rest of network.Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch with a wired PC and web browser. Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-router
michaelkenward
May 05, 2023Guru - Experienced User
Sweetjanaya1 wrote:
What more information is needed?
More information on what is happening at your end.
Networks are complicated beasts with all sorts of things going on. The simple message "2.4GHZ Band not broadcasting" could be down to many things.
You have to play Sherlock Holmes and do some detective work.
You have now added extra information that might help to pin down the problem.
Is it just the TV that can't see the wifi? Or has everything else also lost access?
Have you taken the TV through its network connection process?
The most obvious things to try – I assumed that you'd already done that – is the usual computer trick "turn it off and on".
- Turn off and unplug modem.
- Turn off router and computers.
- Plug in and turn on modem. Wait 2 minutes for it to connect.
- Turn on the router and wait 2 minutes for it to connect.
- Turn on computers and rest of network.
- Leave the TV to last.
Sweetjanaya1
The 2.4 GHZ can't be seen on any devices in my home like before including the cell phone and I am certain it's the modem. I am going to try the tips that were provided to me and I hope it works because my tv is not 5g compatible
