Bry-07
Feb 24, 2024Follower
2.4ghz not connecting
This is *exactly* what I’m going through. Xfinity had a minor outage on Friday and wifi has never been the same. I’ve had zero problems with my wifi or hardware prior to the outage. Just tried fac...
tobraha
Mar 01, 2024Aspirant
For me, the only way to fix it was to factory reset. I used the physical reset button on the modem itself. If I tried importing a configuration backup after the factory reset, it caused the 2.4GHz network to stop working once again. I had to rebuild the configuration from scratch.
I've since upgraded my equipment and I'm no longer using my AC1750 WiFi Cable Modem Router (C6300) for Wi-Fi; I'm now using a full Ubiquiti network stack and the C6300v2 is just my modem.
