Ianhicks
Aug 14, 2022Aspirant
2 Netgear modem/routers, 1 network.
Ok, I have a CAX80 nighthawk and a C7000v2. Following YouTube I cannot put these on 1 network. Mainly because of the password reset loop. But before that I was in and out of crappy firmware Also, i...
Ianhicks
Aug 15, 2022Aspirant
That's exactly what I'm trying to do. Use the other M/R as an access point.
Being this was a Netgear community. I figured this would be the first place to look.
Especially since I'm stuck in the GD reset password loop. Which I've tried on chromo, edge, and Firefox.
Aug 15, 2022Guru - Experienced User
If you have the CAX80 as your main ISP modem, you can use the C series modem as a wired AP if you set the modems router IP address to say 192.168.1.70, set up the wifi on this modem and then shut OFF the DHCP server under Advanced tab/Setup/LAN setup.
You'll need to set the channels on both of the modems to FAR apart channels, CAX80 try 1 and 40 and the C7000 to 11 and 149
Then ethernet connect one of the LAN ports on the C series modem to one of the LAN ports on the back of the CAX80.
- IanhicksAug 15, 2022AspirantAny work on the reset password loop? My research has lead to a dead end. I can work on the setup until tonight, so thanks so far peoples. I would really rather a step by step. Or video. But the hangup is really logging in. So far
- FURRYe38Aug 15, 2022Guru - Experienced User
What reset password loop are you seeing?
Be sure you clear out all browser caches before entering to the modems web page.Try a different browser...MS Edge, Firefox or Opera.
- IanhicksAug 15, 2022AspirantThank you. I will clear the cache and such tonight but it's in the password recovery or reset. It asks 2 security questions. You reset password, it says to enter the new login. And after that it loads right back to the beginning of the password recovery/reset process. After sifting, I believe your advice may help my cause.
