Yaksok8012
Oct 18, 2023Aspirant
220v adapter for nighthawk ac3200 dualband
Hello I have nighthawk dual band ac3200 and will be bringing this to a country that uses 220v outlet. If I get a universal power adapter for 220v, would I still be able to use this modem/router? In ot...
Oct 21, 2023Guru - Experienced User
Take a look at the power supply. some were rated 110-220v. Maybe you'll get lucky.
If not either get an adapter or purchase one of the 220v power supplies.
You might check to see if the isp even supports that device before doing so though
Yaksok8012
Oct 26, 2023Aspirant
Thanks. The power supply is only for 110-120v. But I would like to know whether the model itself can take 220v if I get the 220v power adapter
- plemansOct 26, 2023Guru - Experienced User
The input voltage isn't the biggest concern, its the output.
You can get whatever input voltage you want so long as the matching output is the same.
so get a 220v one. but make sure its output is the same and factory
