jms23
May 18, 2021Tutor
24 channel from 32? / day 8/ unstable xfinity internet / power 14.3 dBmV / SNR 36.5db
xfinity 400Mb service CM1000 V7.01.01 last 8 days internet drops for 10min to 1-2 hours 5-8 times a day. one coax line straight to my cm. Line levels checked at home show the bottom 3-4 cha...
jms23
May 18, 2021Tutor
I would tend to go by your expertise and appreciate the time.
I have a lot of errors on my line and it is from the outside drop back to their service according to the tech.
It is bizarre to me the service provider(comcast) only has nodes that are manageble on the network like 12 miles away. sending guys on polls to change services to adapt to a few modem readings seems like a difficult way to optimize all of the sprectrum they need to manage with docsis to turn it into round trip stable internet.
the tech is in the are and now causing neighbor outages.
I would pay $500+ or more for a service from netgear to manage this and send the needed data back to comcast rather than my last 8 days.
May 18, 2021Guru - Experienced User
hopefully whatever the tech is doing in your area fixes the problem.
If not, many times ISP's like to say "its not our line, its your equipment".
I've actually had to rent a modem for a month to prove it wasn't the equipment before.
And it could actually be the equipment. its always a chance of that.
- jms23May 19, 2021Tutor
one error this morning
RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW
changed my frequencies for downstream to exclude any 700Mhz
clean cm
wait 24hours and post details
- jms23May 23, 2021Tutor
Comcast/xfinity added back the >700Mhz channels to the downstream channels. 2 maintenance outages 5/20 & 2 more 5/21 with 10-20min outages each.
Then went away for the weekend.
Will see what it is Monday for heavy work reliance on this network.
CM status is good now 9:24pmET 5/23/2021.
- FURRYe38May 23, 2021Guru - Experienced User
Keep on the ISP about this. Seems to be on there side of the fence. :smileywink:
