jobrux
Oct 04, 2022Aspirant
30CAXs router modem, trying to change password in Advanced>administration
Not sure how to find firmware, Model is router modem 30CAXs. ISP is Xfinity. I use iphones/windows 10 computers to access. Problem as follows: I would like to change the router password (no...
- Oct 05, 2022
One last note. I went ahead and tested the idea that using <CNTRL>V to do the pasting (instead of mouse right click, then 'paste' option from drop down window) was the reason that my new password was accepted. And I verified that was the reason.
jobrux
Oct 05, 2022Aspirant
Dear Furrye38, thanks for taking the time to respond. I tried several more things: clearing cache on Chrome (did not work), i tried using Edge browser (did not work). Then I started looking at the logs and trying to make sense out of them. Then I decided to try Edge again and for completely unexplained and mysterious reasons, it accepted my new password. This was not the password you suggested and it contained capital/lower use letters, numbers and special characters. So, here I am, left wondering: was it the salt I threw over my left shoulder? was it the special incantation involving candles and sounds (you get the idea...).
I wish I had a better understanding of these things. But I'm going to leave well enough alone for now. Again, thank you for your help.
Jobrux
jobrux
I just remembered something. Normally, when I paste stuff, I right click on my mouse, and a little window pops up with 'paste' as an option, and i click on 'paste' to paste something. I think possibly, my last attempt I used the old windows standby: <CNTRL>V instead of pasting with the mouse. Maybe that was the ticket. I'm not going to mess with this for awhile. But it's at least up here in the forum now.
- jobruxOct 05, 2022Aspirant
- FURRYe38Oct 06, 2022Guru - Experienced User
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
