theaftermath
Aug 17, 2018Aspirant
3400v2 Wired Connection Throttled!
Hello,
A couple weeks ago I upgraded to 100mbs internet and noticed I was only getting around 50-60mbs when connected through the router. When connected directly to the modem (ARRIS) I see 100-110mbs.
I have tested the cables and both transmit the full 100+ so cables are not it. I have reset the router countless times, maybe around 15-20 along with modem reboots throughout also. I have tested all four output channels on the back and they all are the same. After resetting router I have both manually setup and let the wizard setup the connection. I do have the latest firmware version 1.0.0.54_1.0.82
My settings are:
Interent Setup
No login
Get Dynamically from ISP
Get Automatically
Use Default Address
WAN Setup
Only setting checked is Disable IGMP Proxying
1500 MTU size
LAN Setup
I am using Router as DHCP Server
When I check the Internet Port "Show Statistics" it shows the WAN and LAN ports as 100mbs/Full.
Any help please?
Thanks
1 Reply
- theaftermathAspirant
So after do more tests I finally replaced the modem and that cleared it right up.
