Jkeller22
Apr 02, 2022Aspirant
3G. Vs 5G
I have a ring camera, and was on 3G, internet service provider upgraded to 5G, which is not supported with my ring doorbell. How do I get my 3G back? I really need my ring doorbell. Any help, woul...
Jkeller22
Apr 03, 2022Aspirant
Only gives me the 5g to Connect too. No option for the other.
michaelkenward
Apr 03, 2022Guru - Experienced User
What does?
A mobile phone?
Nest really is hopeless in advising users.
If you cannot force your mobile to connect to 2.4 GHz, one way around this is to
- temporarily disable the router's 5 GHz.
- Tell the mobile to forget the 5 GHz SSID.
- Give it a minute or two to forget the 5 GHz wifi connection
- Connect to 2.4 GHz.
- Do your thing with the IoT device
- Enable the 5 GHz wifi
- Complain to the people who made the IoT gadget
You might get better advice if you described what you are doing, what happens and where it goers wrong. So far we have had no much more than "it does not work".
You are not the first person to have come across this issue:
Search - NETGEAR Communities – ring doorbell
and more widely:
- Jkeller22Apr 03, 2022AspirantWhen trying to connect from my mobile phone or iPad, it only allows me to connect to the 5g.
